I am new to using the Acrobat 5.0 and I have been trying to use it for days. I have read at a website that to display the acrobat popup control button, you have to run the code on the Java Script console (i.e. var cRtn = app.popUpMenu("Apples","Oranges","-","Beans","Corn")). I have been trying this but nothing is happening. Might I be doing something wrong? Please help, I am looking forward to your answers. J
Where is the acrobat popup control button?
Hi Asheley Madison,
Before using JavaScript console, try to check your Acrobat Preference setting, then look for the Java script pane, under it you have to make sure you mark the check box "enable Acrobat JavaScript and interactive console".
Hope it helps,
Llison Janneya
Hey,
What I came to understand from whatever you stated above is that you need to use Adobe Acrobat Extended instead of the Acrobat reader tool you are using. For more you can visit the link I am providing you. Simply visit Adobe Extended Acrobat
I hope this will solve your issue.
Thanks & Regards,
Gillam Janetj
