Where is the additional installed brush in Photoshop CS?
I use Photoshop CS. Recently I download some Photoshop brush from internet and install them. But in my brush tools I can not new installed brush. It only shows the old brushes only.
How can I see new brushes and use them? Is there anybody can help me and tell me what is the procedure?
Best Answer by Austin kelley
Answered By 10 points N/A #113609
Whenever launching or determining paint brushes, rather than getting the particular 'abr' data files inside the Styling brushes directory, the actual styling brushes usually do not stay on to brush menu Once you've changed the particular brush set you're using. To learn more about making these kinds of changes long term, or produce clean models of your own, read my tutorial on Creating Brushes.
Answered By 10 points N/A #113610
After download your new brushes, you have to add it inside to the Preset folder. After that you can use your new brushes same as default brushes. Please follow the following steps.
Preset manager >> Select new brush and give a name (if you want) >>Click done button top on the opened dialog window. (After selecting new brushes you can see it inside the opened Preset manager window).
