kent woods
30 points
Posted on - 12/10/2012
I downloaded Archos 5.
I thought Archos 5 codec divx support is available.
But why doesn't it play divx after converting the video using another software. Is it a problem with Archos 5?
Or with the settings during the conversion?
Thanks for enlightening me.
Where is Archos 5 codec DIVX support?
Hi
I also had the same problem.
I used IMTOO toll, which of course supports all file formats, to solve this.
Archos will also work fine or you can also take Hand brake which also supports a lot of formats.
It is important to note that most of the files will not work on your because they were wrongly encoded or malformed.
For the Date Time picker control in MFC I highly recommend you to read and learn the official documentation from MSDN. I’m sure that you already installed this the same time when you installed your Visual Studio application, so please the help documentation from there.
For other useful resources I recommend link from Microsoft.
Also the tutorial on FunctionX site. They have a neat tutorial on how to use it.
If you need other material please don’t hesitate to contact me,
Aabel
