Where are the tab scroll buttons place on excel screen
The tab scroll buttons are present on the right side of the excel. And also you can set them using the edit option in view in the task bar. This is very easy to access this. Just click on the view at the top of the page and then go to the edited option and chose whether you want to show this or not if yes then make it is otherwise make it no it will disappear and this will solve your problem.
So Hope this solution will also get rid of your problem and you will understand how doing this.
To enable/disable the scroll bars in an Excel document, you have to change some settings in the Options dialog box.
Please consider the following procedure:
1. For Excel 2007 click the  button; for Excel 2010 click File.
2. Choose Options and then Advanced on the left side.
3. Scroll down in the right panel until you encounter the title Display options for this workbook.
4. According to what you want to do, check or uncheck the boxes Show horizontal scroll bar and Show vertical scroll bar (see image below)
5. Finally click the OK button.
