Where to buy the Creative Sound Blaster Recon3D PCIe
I am interested in buying a new sound card; does anyone know where i can buy a Creative Sound Blaster Recon3D PCIe?
Hi Halton Roy,
You could buy a Creative Sound Blaster Recon 3D PCIe at www.amazon.com.
The packaging there usually comes with the box sealed and undamaged.
They sell their items as advertised and it usually arrives two days shipping.
The box contained the sound card (Recon3D), a beam forming microphone, and an installation disc along with a quick install guide. It also includes a software for easy installation and it is not a ram hog like some of the old creative tools that has to be installed in order for the card to run it's best.
Also if you want a much cheaper sound blaster you could choose to buy Creative Sound Blaster Recon 3D THX PCIE Sound Card SB1350 that is if you do not want the sound card with frills like the red illumination.
Hope this could help your query.
If you are interested in buying the Sound Blaster Recon3D PCIe sound card, here are a few stores where you can buy it.
At the moment, it is available with one brand new unit that costs $79.99 and one used unit for $64.99. The Creative Sound Blaster Recon3D THX PCIE Sound Card SB1350 sound card supports Windows 7 both 32-bit and 64-bit and requires Intel Core 2 Duo 2.2 GHz or faster processor or AMD equivalent, 1 GB RAM, 600 MB free hard drive space, and x1, x4 or x16 PCI Express slots.
At the moment, this sound card is available with two brand new units for $313.59 and two used units for $199.99. It supports Windows 7 both 32-bit and 64-bit and requires Intel Core 2 Duo 2.2 GHz or faster processor or AMD equivalent, 1 GB RAM, 600 MB free hard drive space, and x1, x4 or x16 PCI Express slots.
