Where to buy WordPress best themes?
I want a wordpress theme for my website but I don't know where to buy the best themes.Please suggest me some websites where I can download some best wordpress themes.
Mr. Arnold Ortiz
I think it’s very important when you choose new Word Press theme for your web site you have to take care of some issues:
1. Maybe you can’t find one of your main plug-in not work with that theme?
2. You have to choose Word Press theme developed just for your work … like Business web sites you have to choose the suitable theme that already made for this kind of websites
Now you can take a look for the best Word Press theme sites:
I hope you can find this information useful .
If you have a WordPress website and thinking of using a theme for it, don’t think of buying a theme specific only for WordPress websites. It is much better if you have or you can create any theme for any website. One program that allows you to create a theme for any types of website is Artisteer. It is a website theme designer for Microsoft Windows that supports WordPress, DotNetNuke, Drupal, Blogger, and Joomla.
With this tool, you can be an instant web design expert. The software allows you to create tons of combinations for your theme. If you want to use an image for your logo, the application automatically resizes and cuts the image according to your desired size. You don’t need to learn how to use Adobe Photoshop or even Dreamweaver and especially no technical skills necessary.
If you want to try Artisteer, you can download it from Artisteer for Windows. Please be reminded that beginning in Artisteer 4.2, themes created in trial version will no longer allow you to export to Drupal, Joomla, and WordPress. I am also using this software, by the way. The one I have is Artisteer 4.0.0.58475.
