Where can find a dot net tray application compiling guide?
ton ytony 10 points N/APosted on - 03/13/2013
I am in a problem with compiling dot net tray. I need assistance about the task. Do you have a clear and trusted instructions about dot net tray application compiling? I have one but that is not clear to me. It will better if I can get video tutorials on dot net tray. Please help me.
Before creating any DotNet tray application please considers the following things:-
The application must exist in the try application.
At a time only a single instance of the application should be running any attempt to start other instance should not be allowed.
While compiling the administrative privileges need to be provided. If you compile using the VB than that is managed by the Visual Basic itself as it would execute the application using the admin privileges.
1....
