I have downloaded a TV driver for my Windows Vista but it is not working. I am having a problem with installation. Where can I find a correct drivers savvy tv for vista? Please suggest me a proper driver.
Where can find a drivers savvy tv for vista?
If you are using a plug and play device then you don't need to install software so first make sure what type of device you are using next check the proper name of the device model and then go to the company website that manufacture that TV devices. You will be able to find the drivers from the website.
If it doesn't work then use skydiver or Universal CD/DVD to check the drivers and it will automatically install them and fix them if there is some issue in drivers.
Darrel R Gonzale
