hugh egnor
20 points
Posted on - 04/04/2013
I have a good ps2 joystick and I can play some game with this. The problem is I can not play some games and but the most issue is I can not use to vibrate. Is the problem with driver? Then from where I can get drivers ps2 joystick?
Where can get drivers ps2 joystick for playing games?
There are a lot of websites that provide the drivers to download without any difficulty.
You can download any driver at anytime from internet without any problem.
PS2 and USB joysticks have a variety of models.
You should note the model of your joystick. Then try to search the driver relating to your device.
I have two websites for you tow download drivers.
Download Drivers Website 1
Download Drivers Website 2
I hope you will get it.
Thanks
