Where can get a PDF to JPG converter freeware?
I need pdf to JPG converter freeware. I have two but those are not good. One gives output but there are several lines with the word “demo” on the background.  Another one needing internet connection and load advertised too. I am confused if this store or steal my data. Is there any pdf to JPG converter freeware that is hassle free and secure?
Answered By 40 points N/A #182646
Dear Alland Ornad,
Thanks for asking.
Dear you cannot convert the PDF file to jpg with any windows utility.
You have to install a third party software. There are many software that can convert the pdf file to jpg image file.
I suggest you to use Nitro PDF Editor. Nitro PDF is a freeware software. You can download it free.
Here is a link to download the Nitro PDF Editor.
https://www.gonitro.com/free-pdf-software
Download the Nitro and open the file into this software.
Export the file to jpg format. It is so simple.
Thanks
