Where can I browse root files android for xp?
I want to arrange my files manually in my android with XP OS. Where can I browse root files android for XP?
Hello Corey,
I guess the best way to do that will be to connect your Android-enabled phone with your PC, and to do that you will need to use a cable or a wireless connection. Once the two devices are connected, you will be able to connect the root files for Android using your computer.
Nicke
You can take help from the software name given below,
PdaNet,
It directly shares the internet access of your Android phone with your computer. It does not have need of root access or modifying your phone's firmware. It works on all android phones.
PdaNet chains both USB Tether and Bluetooth DUN. Your phone can attach to the data service, WiFi or even through VPN and PsNet will share it with your computer.
Thanks
