Where can I buy cheap laptop?
Where can I buy cheap laptop having a good specification and quality, what is its brand and what is the best season to buy it?
You can try the Acer Aspire 5349 which cost $280 and they also have a refurbished model that you can buy on cheaper price. This Acer Aspire has a reasonable specifications at a very affordable price.
This is a good deal considering that it has a dual-core Intel Processor which is best for Office applications, sending emails and surfing the net. Refurb or Refurbished models has some slight damage on its design or it may have been sold and returned due to some minor issues.
The specifications of Acer Aspire 5349 are the following:
– Intel GMA Dual Core B800, 1.5GHz Processor
– 6GB RAM
– 750GB Hard Disk Drive Capacity
– DVD +/- RW Optical Drive
– 15.6" Widescreen with 1366 x 768 Screen Resolution
– Intel GMA Graphics Card
– Windows 7 Home Premium
You can go to the following websites for a great laptop deals:
http://www.pricegrabber.com/laptopcomputers/browse/
Hello Madison,
There are many places you can get an affordable laptop, but then you will have to put the needs you want to use that laptop for in mind. For instance, if you are a student, then laptop you will get won't be like that a journalist or a news anchor will need. Some of the places you will get the laptop include the following:
Carl
