jeff mathie
30 points
Posted on - 06/29/2012
Game developers went another step further by bringing your favorite fighter plane games on your smartphone to reality. Reality being a foam fighter plane that can be controlled by your smartphone.
Where can I buy a foam fighter plane? What designs are available?
Where can I buy the Foam Fighter for Smartphones?
This is a new game that I’m sure lots of game enthusiasts will love. To play Foam Fighters, you need to download and install the application first which is available in these versions:
From the main menu, select Profile or Campaign. You are required to scan the plane with your Smartphone by holding it in front of your Smartphone camera. The application will then identify which model it is which in turn unlocks the plane’s missions. You are only required to scan every plane once. The next thing to do is to attach the plane right on to your device or Smartphone. The plane needs to be placed in front of your Smartphone’s camera so you can watch it as it fights, digitally flies, and suffers damage. Described below are the steps on attaching the plane on to your Smartphone.
Stick the suction cup on to your Smartphone’s camera lens then press down in the center to take out the air.
Tighten the knob on the suction cup. The knob must be wind down before placing it on to your Smartphone and then secure the plane in place.
Adjust the arm when you are prompted by the application to make sure the plane is properly positioned in your Smartphone.
To learn more about the game, visit APPGEAR | Foam Fighters. To buy it, visit WowWee® – Astonishing Imagination | AppGear Foam Fighters. It is priced at $9.99 USD.
