Where can i buy the iPhone Scuba Suit?
Definitely the iPhone scuba suit can give all the glory of taking photos underwater. This is factory tested and one hundred percent waterproof. The suit is airtight and no drop of liquid can enter the suit. This will keep your gadget safe from damage. There is no question on its quality of taking a photo underwater with the suit and without the suit if you’re not underwater of course.
With this suit you can take all the photos that you were unable to take because of the damaging water.
You can order it at any shop cart and yes they can ship it to your in any country you were in just find it in the shop cart. But beware some say that it does not work on the water as much as this suit is concerned. Some testimonials says that it does work. It’s your own prerogative if you will buy or not. But these are the information I know about the suit.
Notifications
