Pam Gouin
10 points
Posted on - 02/13/2013
My Lenovo's battery drains too fast. I'm only having 8 hours standby time out of it. My laptop is a Lenovo Ideapad G565 with AMD Phenom II N850 processor, 4 GGB DDR3 Memory, AMD 785GX Motherboard and ATI Radeon HD 5470 Graphics Card. Where can I find an extended battery for my Lenovo?
Where can I buy Lenovo ideapad g565 extended battery?
Hi Pam,
Here are some tips on getting a maximum battery life for your Lenovo. You should condition your battery, that means fully discharging and then fully charging it every three or four weeks. If you fail to do this, it will significantly shorten your battery's life. If your laptop will not be used for a month or so, I recommend to remove the battery from your laptop and store it in a cool dry place. A battery will gradually lose its power if unused for a long time. Therefore it is necessary to recharge it after a storage period. However, if you still want a replacement battery, you can buy one at the link below.
http://www.batteryoffice.com/lenovo-ideapad-g565-battery.htm
Hope it helps,
Korber Owen
