I just bought Phonak Audeo PFE 022 + Mic earphones for my Samsung Galaxy S i9000 to have that rich bass feel but won't work. So now I'm looking for the stock 3.5 mm Samsung Galaxy S earphones. Anyone know where I can buy and how much? Thanks.
Where can I buy Samsung galaxy s earphones?
Hi Denise
I have also a Samsung Galaxy S Phone, but I have an original Nokia earphones and it also works so fine. Anyway, you can buy 3.5 mm Samsung Galaxy S earphones at Amazon.com. I found the earphones that you’ve been looking for in this website for only $8.95.
Here is the link: Samsung Galaxy S 3.5mm stereo Headset
I hope this helps.
Hello, 3.5 mm earphones come standard with most phones these days.
The music quality is not as good as you would otherwise get with premium earphones and more often than not, you end up with the same music quality you were hoping to upgrade.
However, there is lit at the end of the tunnel.
Hope you will find a these beauties likable.
Samsung 3.5 mm Premium Stereo Headset Bulk Packaging – Black
