Where can I download acronis true image home 13?
I heard that acronis true image home 13 was just release. Is it free to use or do I need to buy it? If so, where can I download it for free? Many thanks..
Hello! Here are three sites I found where you can download Acronis True Image Home 13.
https://www.acronis.com/en-us/personal/computer-backup/
On the first site, above, you will have to buy it for $29.99, but a free trial is presented there too.
http://download.cnet.com/Acronis-True-Image/3000-2242_4-10168093.html
Acronis is free to download on the second site.
https://acronis-true-image.en.softonic.com/
On this last site, there is a lot of Acronis versions to choose from. Check it out.
The latest version at the moment is Acronis True Image 2018 and for Microsoft Windows, it supports Windows XP Service Pack 3 (32-bit only), Windows 7 Service Pack 1, Windows 8.x, and Windows 10 including Windows Home Server. For the Apple Macintosh computer, it supports OS X 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, and 10.13 High Sierra. The following file systems are supported in the latest version:
Acronis True Image 2018 also supports Android 4.1 Jelly Bean or higher and iOS 8.0 or higher. You can buy Acronis True Image 2018 from $49.99 and from $29.99 for upgrades. You can also download the trial version.
