Hi.
Where can I download Lavasoft Adware freeware anti-virus version 10.5.1?
I want to try it out since Avast and Norton 360 could not delete some Win32 Trojans and malware.
Would it be compatible with a Windows 8 Metro OS?
Any suggestions or tips would be highly appreciated.
Thank you.
Where can I download Adware freeware antivirus?
There are many brands of antivirus software. Most of them are paid, and some of them are free. Adware Freeware Antivirus is a freeware antivirus software, and you can use it without any cost.
Yes, it is compatible with Windows 8 OS, and you can use it easily. It keeps you safe from all Trojans and Malware.
Download the Lavasoft Adware Freeware Antivirus, Version 10.5.1.
First, they give you a 30-day trial.
Then, activate it’s lifetime usage with your email ID
Hello Caroline,
Have you tried AVG antivirus or Avira antivirus. They are the most reliable antivirus for any machine. AVG antivirus is highly recommended.
It scans the whole computer in depth and removes all types of Trojan virus. I used it and it did pretty well for me.
I suggest you to try AVG antivirus first.
If still you want download Lava soft Adware antivirus then you can download it from their official website.
This will help you.
Lavasoft free antivirus is now known as Adaware. If you want to install it on your Windows 8, there should be no problem because it is fully supported. If you want to try this, download the latest Adaware Free Antivirus. It supports Windows 7, Windows 8.x, and Windows 10. Microsoft Windows XP and Microsoft Windows Vista are not supported.
It requires 1.6 MHz or faster processor, 1 GB RAM, 1.8 GB free space, and Windows Installer 4.5 or higher. If your computer was previously infected by a virus, scan it first with a virus removal tool. Download Sophos Virus Removal Tool and install it. Once installed, start Sophos and wait until its virus definitions gets updated. When the program is ready, click “Scan” to scan your machine.
It will scan your entire computer as well as any devices connected to the USB port. When a virus is found at the end of the scan, remove it and then repeat the scan until it no longer detects a virus. When the machine is clean, install your new antivirus program.
