avis duby
Posted on - 02/20/2013
I have used Babylon for my PC for ages. Ranging from XP to Windows 7. It is very convenient as it has a text translation in a single click and a built-in spell checker. I have recently shifted to OSx. Where can I download Babylon for Mac? I'm on OSx Snow Leopard. Thanks.
Hi there user:
I understand that you have used to Babylon because it is convenient for you. No worries, I will help you get Babylon to your Mac. Here’s the link or site to download Babylon for your Mac. http://mac.brothersoft.com/babylon-download.html Just choose your desired the download option.
I hope this could help you. Thank you for asking.
Hi Avia,
As a word of caution, I would advise you to avoid using babylon tool bar as it has been identified as a malware and browser hijacker which will track your system usages. It is very difficult to uninstall it from your PC. You can explore other options to get your requirements fulfilled. Most modern browsers support translation natively and also support spell check. Or there are software like ginger software which does spell check. You can right click on the page and choose translate.
Hope this helps.
