Where can I download classic Windows 98 icon pack?
Hello!
I checked out the classic windows 98 icon pack and I like it. I would like to download it but I have no idea where from. Where can I download classic Windows 98 icon pack? It does not matter whether it comes as one of the common zip files. I will wholeheartedly appreciate.
Best Answer by Morse Joseph
Answered By 0 points N/A #164716
Hi Pottey,
You can get the classic windows 98 icon pack and download it from the following link for free.
http://www.nirsoft.net/utils/iconsext.html
The download is in  zip file format and it is compatible With the following operating systems: windows 95/98/ME, Windows NT , Windows 2000, Windows Vista/7/2008, Windows XP,Windows 2003 Server.
Answered By 0 points N/A #164717
Hello Pottey,
You can find classic windows 98 icon pack at ICONFINDER.You can get more than 3000 icons where a large number of them are for free and some of them are paid.You have to select your desired icon and can download it within three formats.
They are:
1. PNG
2. ICO
3. ICNS
These icons are compatible With the operating systems like windows 95/98/ME, Windows 2000, Windows 2003 Server,  Windows XP,Windows Vista/7/2008.
Answered By 0 points N/A #164718
If you already using Windows 7 and Windows XP you can actually get the classic Window 98 icons manually check the video embedded below as a tutorial and if you want the Windows 98 theme you can also do it yourself Wonder how to
And check softonic there are lots of option there depending on what you need.
