Where can i download collegiate font for ms word?
I am just wondering where I can download collegiate font for ms word for free and how to save it on my computer.
There are several websites offering the font you need. you can search them using Google,yahoo or Bing search ( I prefer Google)
And type the collegiate font in the search box.
There will be several websites to choose from & most of them are free.
here are some of the links for the websites:
http://www.fontspace.com/character/collegiate-heavy-outline
https://www.dafont.com/sf-collegiate.font
https://prepresstoolkit.com/25-free-college-fonts/
http://www.fonts101.com/fonts/view/Standard/10748/CollegiateNormal
once you have downloaded your desired font open the fonts folder located in c:windowsfonts then drag the font file you have downloaded in the folder it will ask you to install the font. after installation open MS Word or your document editor and you will find your new font there.
I hope this helps.
thank you.
Hi. Go to www.dafont.com and then type the font style you were looking for on the search box. Click the Download button on the upper right side of each font style and save it on your C:/>Documents and settings. When done saving, open your documents and Settings folder and then right-click the zip file to extract it.
To add this font on your MS Word, go to Control Panel>Fonts. Click the font icon box to view all the fonts on your computer. And then go to File>Install new font, a window will open, go to Folders on that window and then click C:/>Documents and Settings. Click the font you want to add from the list of fonts and click OK.
If you want to use collegiate fonts in Microsoft Office Word, try downloading from the following websites:
Once you’ve downloaded the fonts you like, installing them is easy. Click “Start,” “Control Panel,” “Appearance and Themes,” and then click “Fonts” on the left pane.
On the next screen, click “File” and then “Install New Font.” Navigate to the location where you downloaded the fonts then click “Select All” and then “OK.” Once the fonts are installed, you can now use them when composing a document in Office Word and other programs. If the fonts you downloaded are in ZIP files, unpack them using 7-Zip.
Notifications
