raidernet
10 points
Posted on - 08/05/2011
Recently i format my HP pavilion DV2700c notebook, I downgraded from Windows Vista to Windows XP.
Following simple steps of formatting, then my next move should be installing the drivers of each device like the VGA, AUDIO, Fingerprint scanner and more devices. My problem is where can i download the drivers for my notebook since the driver i had where only compatible for windows vista. I've tried to search the Google but all process just doesn't work. Its been quite sometimes already since my notebook was stock.
Where can i download the Driver of HP Pavillion
Try to download form hp support. You can find by searching hp home.Â
Follow the instructions to get appropriate driver for your laptop.
Now go to:
http://welcome.hp.com/country/us/en/welcome.html
Select support and drivers page.
https://support.hp.com/us-en/
Select driver and software, write your product specification. Like model and name.Â
It will take you to a product list. Hope you will see your product in the list.Â
Chose your product form the list of products.
Finally select operating system.
Select your desired language. Start download drivers that you need.Â
Hope you will find driver for windows XP.Â
If still you did not find driver please contact your supplier for it.
gracejov
5 points
Hi good day,
- Try to visit this site: https://support.hp.com/us-en/drivers and identify your product by selecting what type of device are you using. Then enter the serial number of your device.
- How to locate my serial number?
- Simple the location in the serial number is on the side of the laptop or at the back of the laptop. Then select the operating system that you use, example: Windows XP, Windows 7 and Vista. Click next and enter >> the email is needed.
- Note: Remember please read carefully while you proceeding your task.
Thank you, hope its help.
Regards;
Gracejov
