Where can I download free Google earth pro 5
Hello techyv.com!
What I have here is lenovo laptop with os of windows 7. I want a free google earth to explore the world, hence finding some good tourist spots worldwide. My friend told me to download google earth pro 5 because it is good and I can download it legally for free. May I ask where can I download a safe and free earth pro 5? Thanks!
Best Answer by Burch Patterson
Answered By 50 points N/A #170676
Greetings! Sadly, you cannot download Google Earth Pro and use it without limits without buying the software.
Remember that there are laws to using software illegally without buying the purchase if you are caught.
You can either buy the Pro edition or you may simply use the Free edition which has most of the basic features of Google Earth.
Cheers!
Answered By 0 points N/A #170678
There are some features which you need to have in your PC.
And a compatible OS For the Google earth you want to download..
To download you will need to edit the softonic.com in your internet grid search command  then get your downloading process. When there is a command of save or run file just enable by save .
Then it will .directly save to the downloads folder.
Answered By 590495 points N/A #315746
If you want to install Google Earth, you can download the standalone installer. The default download page for Google Earth downloads the web installer. For the standalone installer, go to Update Google Earth Pro. Here, under “Download Google Earth Pro for desktop”, click “Download a Google Earth Pro direct installer” to expand the list. The latest version at the moment is Google Earth 7.3.2.
Download the version for your operating system. The 32-bit version is around 54.9 MB and the 64-bit version is 61.6 MB. You can also download several of the older versions. Before downloading any earlier versions, make sure to read the notes so you won’t have a problem installing.
