Hi all,
Can someone please help me on where I can download the PDF Creator Linux Mint? I need it free or if I need to purchase it, it will be fine with me. As long as the software is legit and can be downloaded from a trusted website.
Where can i download Free PDF creator Linux Mint?
In this site, you can choose a number of PDF creators that could be fitted to your needs and to your Linux:
http://ptf.com/pdf/pdf+creator+linux+int/
There is Foxit PDF Creator 3.0, PDF Creator Plus 5.0.005, PDF-Creator 3.0, PDF Creator 7.0, Sonic PDF Creator 3.0.5, and Smart PDF Creator Pro 6.3.0.495. Â
The first two (2) are free to download.
Hello Wallace Browning,
There are a number of websites that offer you to create a pdf version of you document. The process is quick and free. What you have to do is that you go to such a website and upload your document, it will convert the file and give you a download link to the pdf version. Here is a link to such a website:Â https://www.freepdfconvert.com/
If you want a software which you can use offline to create pdf document then I suggest you use this software:Â https://www.scribus.net/scribus-1-4-6-released/
