Where can I download freeware network calendar?
I need it for my team (local network connection) to manage weekly activities.Â
Please recommend good freeware network calendar.
Thanks!
Thanks!
Dear user,
Top free online calendars include;
On where to download, I cannot give you the exact links but try and click on the links provided on the list of calendars.
Hope this will be useful.
Hi Nelson,
I've found a good LAN calendar for you. This is free of cost and meets your requirements of managing your weekly schedule and activities over the network.
This requires to be installed on every node of computer on your network from which you want to access this to be used.
This is extremely easy to setup and use.
You can find the link below.
Link:Â http://download.cnet.com/VueMinder-Lite/3000-2124_4-10964293.html
Hope this helps!
Drianna allen
