Where can I download Fujitsu update manager for my scanner?
Hello Guys! I would like to download Fujitsu update manager for my scanner. I enabled automatic updates for my scanner but apparently I realize that it lags behind even when new updates are already out. How can I download this manager? Is the update manager giving up to date information on new drivers and software products by Fujitsu?
Best Answer by Herbert J Smitherman
Answered By 10 points N/A #177526
Hello Javierjohnathan,
You could visit the below link for Scanner Central Admin Software of Fujitsu for updating your scanner driver and follow the process,
http://www.fujitsu.com/global/support/products/computing/peripheral/scanners/fi/software/sca.html
Or go here:
I hope you could figure it out. Thanks.
Answered By 25 points N/A #177527
Here you didn’t mention your scanner model. Ok, no problem. First uninstall the device from the computer, then restart it.
Just go to the official site of Fujitsu.
Then search driver by your scanner model number, download its driver and then install it your computer.
I think it will work for you.
Answered By 590495 points N/A #317446
With Fujitsu, you have two options for the download manager: Driver Manager and DeskUpdate. The Fujitsu Driver Manager helps you update your drivers by connecting you with the Fujitsu driver inventory on the internet then collect the drivers suitable for your network and then downloads the complete driver package. Its main job is to download the package only. For the installation, you have to install the package manually.
For the Fujitsu DeskUpdate, it searches the Fujitsu database for new drivers, BIOS updates, and system-specific software packages for your system. Based on the result, you can then decide which of the identified packages should be locally installed. After this, Fujitsu DeskUpdate downloads the required software packages and installs them. A third program that might be useful is DeskUpdate Manager.
It allows you to prepare drivers suitable for your Fujitsu client computing devices. It connects you with the Fujitsu driver inventory and gathers the drivers and installation tools which will then be downloaded and stored into a driver repository. Afterwards, you can use your software installation system to distribute and install the drivers automatically with the DeskUpdate command line tool called “DUCMD”.
The Fujitsu DeskUpdate Manager is not free though but you can download the demo version. You can download these programs from here:
