Where can I download liquid edition win 7?
Someone recently handed me a Pinnacle Liquid Pro Version 6 hardware which can easily import native HDV without conversion.  Would it be compatible with Windows 7?  I have Pentium 4 2.66 GHz with 2 G RAM and OS Windows 7 64 bit.  Where can I download liquid edition win 7?
Answered By 240 points N/A #162803
Hi Ann,
I believe I will be able to help you solve your problem or the issue your facing here in the best way possible since there are other users who have experienced the same and had the issue sorted. You will need to navigate to this website; http://www.liutilities.com/device-driver/pinnacle-systems-liquid-edition-pro-device/
You will be prompted to scan your device before installing the software to ensure there are no harmful files in the software or in the computer that can harm the software and the registry. Once you download, you can follow the prompts to install and your software will be ready to use.
Ensure to restart your computer for effective changes to take place.
I hope this solves your query
Thanks
