Where can I download nice business E71 themes for free?
Where can I download nice business E71 themes for free? I use my E71 for my business so when my client sees my phone I would give the impression that I am professional.
Best Answer by assadullah91
Answered By 0 points N/A #169175
Yes, There are Many Web sites for your purpose, just try
  • www.ownskin.com
  • www.mobile9.com
And your Nokia OVI store also. Use non colorful and non fancy Classic themes. That just Impress about your Professional.
Good luck.
Answered By 0 points N/A #169176
There are several sites where you can download themes for Nokia E71. The files should be in .nth format. Check out these sites:
1. https://www.mobango.com/ – You can either login and select the model type of your phone and the available themes will be displayed. Just transfer it to your phone.
2. Symbianthemes.us â€“ Just click on the display theme and download.
3. Brighthub.com â€“ This site gives you a review of each theme and click on the display to download.
4. Mobile9.com â€“ This site has a variety of themes to choose from. Just click on the display and download.
Hope this works for you. Enjoy.
Answered By 0 points N/A #169177
Hi Smith Agail,
There are number of websites which provide the facility for downloading of themes especially for the nokia cell phones. I would recommend you to just go to some search engine and try out your search there. google out you question and you will easily find the answer off your question. As you will search it you will get the number of links enlisted in front of you and check them out. However for your convenience you can check out the links which i have found by searching for you on Google.com.
The links are as follows:
www.webtopicture.com/e71/e71–business–themes.html
www.dailymobile.net/2009/02/04/nokia-e71–themes/
www.themes5.com/…themes/download-Black_Business_Satio_35-97…
com-themes.com/en/For-Nokia-E71/?q=black%20business
Check out the above provided links for your desire. I hope you will find some which you would like.
