Where can i download Plugin ssl 400 for pro tools?
Hello techyv,
I am using Windows 7 in which I have installed pro tools 7.1. Friends, Pro Tools 7.1 is the widely used audio production software, which enable you to record, compose, edit, and mix the sound.
I want to download SSL plug in bundle from the waves so please anybody can help me from where can I download plugin SSL 400 for my pro tools audio software?
Waiting for your help.
Allan
Best Answer by Luker Malcom
Answered By 0 points N/A #169611
After a short research I found a website which provides you with all plugins for your pro tools 7.1. It is categorized into 15 categories including: waves modeling, vocal, meters, surround, effects, limiters etc.
After you select one of plugins you will get the picture along with additional information about your plugin.
Link: https://www.waves.com/plugins
Answered By 5 points N/A #169612
To produce quality sounds and music, you must have the top of the line software.
Wave SSL 4000 Channel Strip Plugin is the perfect choice because it features high pass filter, low pass filter and four-band parametric equalizer to produce outstanding sound. This program is developed under Solid State Logic license and is compatible with Mac and Windows PC.
To get a demo or download this plugin, Click on this link and it will direct you to the website.
