Where can I download quotations on my computer in tamil?
I want to download quotations on computer in tamil. Is there any site to download for free? Is Tamil Keyboard 1.0.0 helpful?
Hi Robert :
For free Tamil quote use this site http://tamilcube.com/res/tamil-quotes.aspx
And keyboard 1.0.0 is easy to use. It can be type by mouse click
 You can find daily inspirational quote From Edgar Cayce' delivers daily inspirational quotes by America's most famous psychic.
 For more information visit https://www.pinterest.com/pin/721209327797744651/
THANKS.Â
Hi Roberts!
You can find free Tamil quotes in this site: http://tamilcube.com/res/tamil-quotes.aspx
The Tamil Keyboard 1.0.0 is easy to use and you don’t have to change your existing keyboard. The application allows you to type in any Windows applications and is Unicode compliant.
There are also virtual Tamil Keyboards online that you can use and they are free. Although you would need to copy and paste the text in to your word processors, excel sheets and etc.
