I am looking for a site where I can download the drivers for Samsung Wave II phone. I am currently trying to unlock my mobile phone but when I plug it on my Win 7 computer, it keeps asking me for the driver. Is there a website where I can download drivers for Samsung Wave II?
Where can i download Samsung Wave II drivers?
Hi there,
You can download your correct Samsung wave driver at the link below.
http://www.samsung.com/uk/support/model/GT-S8500BAAXEU
If you have a different handset model, then just type your correct model no in the search box and you will be able to get your desired driver for the Samsung wave phone.
This is an official Samsung web link which would surely fetch you the end result.
Hope this helps.
Thanks
Baker
Hi Kimghartwick,
To add more details, If you are looking for the Samsung S8530 Wave II (model number S8530)
For Windows 7 it has drivers available like SAMSUNG Kies, PC Sync and Internet Connection Manager,Tethering. Just download what driver you are looking for, probably it would be SAMSUNG Kies, PC Sync.
Hope this will solve your problem. Don't hesitate to ask for any questions if you have.
Thanks
