From Where can i download screen print 32 freeware
Is screen print 32 a freeware, if so where can i download screen print 32 freeware. also advice on whether we can print a selected area of the screen using that ?
Hi there,
Screen print 32 is also like a print screen on your computer right? And yes it is for free, you can download it different sites in the internet. You can also try to download it from this site, http://download.cnet.com/archive/3000-2072_4-10167205.html and you are also asking whether you can print a selected area of the screen using that. The answer is yes you can select and print any selected part of your screen using this software.
Hello Prajimahe,
Yes, Screen Print 32 is a freeware and it is available for free on the web.
This does have a feature where you can print the selected area of the screen.
You can download it from http://screenprint32.software.informer.com/Â and there any many other websites which offers a free download.
Go to www.google.com and type Screen Print 32 and you will see many which offers a free download.
Hope the above information helps!
Keaton Christopher
