Hi and good day to all IT experts!
I am looking for a program called Smart Assembly 5, which will help me to protect my applications against reverse-engineering, manipulation and modification. I don’t like also that my VB.net will be exposed internationally and want to protect my intellectual properties. I really need your help. Do you have any idea where can I download Smart Assembly 5 software? I will appreciate your kind assistance in this matter. Thanks a lot Techvy.com!
Where can I download Smart Assembly 5?
Yes Smart Assembly desperately needed if you want to protect your intellectual property or against reverse engg, cracking or modification, Smart Assembly software will be essential for your data, Now I'm sending you a link from where you can have this software, Plus you can get lot more info about this software
https://www.red-gate.com/products/dotnet-development/smartassembly/
Thanks
You have to follow some actions to get the Smart Assembly 5 software so that you may protect your intellectual properties.
1. Go the Google’s search bar.
2. Search for the Assembly software and find the right one you want.
3. Then download it to properly solve your problem.
I also recommend you a website where you can get this Smart Assembly software. Now you can protect all your applications against cracking and modification. You have to click on the following link to download this software.
