Where can I download the software for the Vivitar 5195 Digital Camera
I removed the software of my Vivitar 5195 Digital Camera from my computer. Now, I want to re-install it but the problem is I do not have the installation disk with me as I am now abroad. Is it possible for me to find and download the software from the internet? Where can I get the link?
Best Answer by Trevor
Answered By 0 points N/A #106953
I have tried searching software for your product but I can’t find one on the internet even in the support site if Vivitar – http://www.vivitar.com/. Since the internet is too wide, there’s a possibility that you may find what I can’t find. Just give a try, nothing to lose.
Another solution that I think is more effective is to ask someone in your homeland to copy the disk then upload it in the internet. You may upload those files with free file hosting sites like Mediafire or if you know the DropBox it may help you a lot. Anywhere you are, you may install your application if you have this one uploaded on the internet.
Good Luck!
Answered By -5 points N/A #106954
Hi Sonia,
If you are having problems downloading the software or driver for your Vivitar 5195 Digital Camera, I recommend visiting a couple of sites below, and find out the most appropriate driver to work for your camera.
 http://www.vivitar.com/support
http://www.fixya.com/search/p443103-vivitar_vivicam_5100_digital_camera/5195
Answered By 590495 points N/A #327795
If you have a Vivitar camera that you need to install back on your computer but you no longer have the installation CD, try downloading from the following:
  • Vivitar Mini Digital Camera Driver – works on Windows 95, Windows 98, Windows 98 Second Edition, Windows Millennium, Windows NT 4.0, Windows 2000, Windows XP, and Windows Vista including Windows Server 2003
  • Sakar Vivitar Free Driver – works on Windows Millennium, Windows XP, and Windows Vista
If none of these drivers work on your camera, you can download and use ManyCam instead. It works on any webcam as long as your operating system is supported. It supports Windows 7, Windows 8.1, and Windows 10 and requires Intel Core i3 or faster processor, 2 GB RAM, and internet connection for subscription activation.
