I have a 15.6" Toshiba Satellite S850 with Intel Core i7, 2 GB AMD Radeon discrete graphics card, HDMI output, 4 GB RAM and Windows 8 OS. Where can I download Toshiba Programming console 3.0 so I could customize my settings and maximize utilities of my laptop? Any suggestions other than the Toshiba website? I'm having errors when downloading from them. Thanks.
Where can I download Toshiba programming console?
Hello Matland Maud,
The software you are looking for should be included in the software that came with your notebook. If you don't have a CD, you can always  try asking at the nearest Toshiba seller to provide you one.
Besides on the Toshiba website, software can be found and downloaded from the mirrors on the most driver catalog web sites, like
http://drivers.softpedia.com.
Toshiba Satellite S850 is one of the products of Toshiba that has an excellent battery life lasting for about 2.5 to 3 hours with normal use. The Toshiba Programming console 3.0 software could be use to customize the settings and be able to maximize the use of the utilities of the laptop. You can download this software at http://softwaretopic.informer.com/toshiba-programming-console/
If still, a problem would occur in downloading, you can visit the nearest Toshiba center.
If the software you are looking for is from Toshiba, you can surely find it on the Toshiba website or on the manufacturer’s website. To get the complete set of drivers for your Toshiba laptop as well as other laptop brands and models, check the following list of manufacturers and download the driver software from there:
Here, enter your laptop’s serial number or model number then click to search. You can find the serial number or model number printed on the sticker on the side or bottom of your device. When your device is located, click it to go to the download page. On the next page, go to the drivers download section or tab.
The page should detect your operating system automatically. If the page shows a different operating system, click to change then select your correct operating system. Download and install all available drivers and software for your machine.
