Where can I download updated industrial icq skin?
I find my ICQ skins boring. I want to change the skin. Where can I download updated industrial ICQ skin? I also want to keep updated. Where do I find them?
Hello!
First, you will need ICQ Plus for you to be able to make use of the skins. Here is the link where you can download the software
http://ptf.com/download/icq_plus/07398/
1. Click the “Download: icq_plus.exe “ button
2. “Your download should begin shortly.” Box will be shown on the next page.
3. A window will appear. Click “Keep” to save the file. Install and restart your computer.
Now you can apply one of the ICQ skins that you downloaded.
1. Open ICQ then click on the main page button
2. There will be a new option “Plus”. Click on it.
3. This will show your ICQ skin window. Click on import and look for the location where you downloaded your ICQ skin. Click on it and click open or double-click the file.
4. Now select the desired skin and click apply.
You can download ICQ skins from this site:
http://www.themesunlimited.com/catFrame.asp?MID=2
