Where can I download vmware iso image for HP?
Where can I download VMware ISO image for HP guest OS and make it accessible to multiple users?  I'm on Windows XP 32 bit sp2 and VMware ESXi 5.1.0.  Will it also work on a 32 bit system?  Thanks in advance.
Best Answer by Fraserr Dawn
Answered By 0 points N/A #182779
            For the VMware ESXi 5.1 you can download it here and for VMware ISO image or any other VMware products, just download it here there are lots of VMware that you can find in here. And about the question will it run on a 32 bit system, the answer is “yes” the VMware product was originally for a 32 bit systems but because of the appearance of higher bit systems the VMware adopted it so it can be used by other OS.
Answered By 0 points N/A #182780
Hello Fred,
Most of the VMware software's require 64 bit systems. Still there are certain software's which are compatible with 32 bit as well. Please visit any of the links given below to download VMware for your machine.
1. VMware for 32 bit and 64 bit.
2. VMware ESXi is free software is for server virtualization compatible with your machine.
3. VMware Workstation This is the video tutorial for downloading and installing the VMware software
Visit any of the link and download it. Also read the compatibility with your system.
Thanks
