I installed Webpoint skin 3.8.0 Level 1 patch for vbulletin on my Windows 7 32 bit PC. The skin itself works fine but the webpoint.xml plug-in won't work. Am I missing anything? Please help on where I can download web point vbulletin style skin that works.
Where can I download web point vbulletin style skin that works?
You can download the application from some of the following certified sites: You will download them through the help of the following Downloader. Download Internet Download Manager: high speed download accelerator. Install the application, then use it to download the theme.
During the installation of the theme, your screen might flicker to adjust to the theme's resolution.
Download
