Where can I download whats app for iPhone 3gs?
I’ve been searching over the internet about the application called what app for my iPhone 3gs but I couldn’t find one. Where can I possible download what app for iPhone 3gs.
You can download What app from iTunes directly into your iPhone or use this link:
Download it to you PC then sync this app with your iPhone 3gs using iTunes utility. But it must be noted that What app requires iOS greater than or equivalent to 3.1.
Good luck.
If you don't found WhatsApp on iTunes then You can download it from WhatsApp's own websiteÂ
1. Go to Whatsapp website.
2. Choose your platform i mean iphone .
 It will takes you to iTunes download page. Then Download it from there .
Thank you
If you want to install the app called WhatsApp, you can always find it on iTunes. But before downloading it, make sure it is compatible with your handset’s current iOS version. Your Apple iPhone 3GS runs on iOS 3 but it can be upgraded to iOS 6.1.6. The latest version of WhatsApp requires iOS 6 and higher.
So, if your handset has not been updated yet and still runs on its original operating system, you will not be able to install WhatsApp. To successfully install WhatsApp on your iPhone 3GS Smartphone, you should update it to iOS 6.1.6. To download WhatsApp, go to WhatsApp Messenger on iTunes. The latest version is WhatsApp 2.16.7 released on July 25, 2016.
It requires iOS 6 or higher and is compatible with iPhone. The WhatsApp Messenger app is a free messaging application available for iPhone and other Smartphones and also available for Android devices. The app utilizes your handset’s internet connection to allow you to send messages and call friends and family.
