Where can I download a working Logic free trial for pc?
Where can I find a working Logic free trial for the PC?  I'd like to try it out first before I buy the Logic Pro 9. I'm a budding musician/producer and I'd like to compare the capabilities of Logic and GarageBand. I would like to write, edit and mix songs in mp3 and MIDI file format with this software. I'm on Windows 7 64 bit.
Best Answer by p Vhilary
Answered By 0 points N/A #170387
Hello Bernard,
Unfortunately there is no Demo or Free Trial for Logic Pro 9, so you actually can't test it before you buy it. On the other hand you can see some videos from Apple about Logic Pro 9 to satisfy your curiosity: https://www.apple.com/logic-pro/in-depth/
Also there are many reviews, tutorials and showcases of Logic Pro 9 on YouTube, so you can make a search there and see if you really like it and how the software can help you accomplish your goals.
P Vhilary
Answered By 0 points N/A #170388
Hello there,
You can try to download this application from this hyperlink Logic Pro.
The size of the file is 5.07 MB but the size of the paid version is is 9000 MB and the price is $499.
You can also try this hyperlink Logic Pro 91.8.
This software is compatible with Windows OS.
Below are screenshots of the Logic Pro.
