Harold Rudy
50 points
Posted on - 10/27/2012
Hello experts,
Where can I edit those pictures of coloring numbers bowling? My nephew has a project and I have to make it presentable and cool, can you suggest or name some software that will probably help me edit those photos? Also include the possible features and advantages of each software, thank you.
Dear Harold Rudy,
Try using MS paint. It’s a simple painting program that can be used to edit the coloring numbers. Play on the tools it’s very simple to use. Or you can try Photoshop its and advance editing software that could give you the presentable and cool effects that you need. Read or watch video tutorials on how to remove and replace color surely you’ll have fun doing it.
Good luck editing.
Hi Harold Rudy,
I think you should try Photoshop. It has many features, tools, filters… for you to edit coloring numbers bowling pictures. You can make them more realistic or abstracted.
Another program I think you can use is GIMP. This soft also has many tools, filters for your creation. However, unlike Photoshop, it is a freeware. You can download GIMP at https://www.gimp.org/
Hope this helps
