Trish Moris
40 points
Posted on - 02/07/2013
I have a Samsung SIII with Android Ice Cream Sandwich and I use a 3gp player on my phone. What is a good 3gp mobile converter? I need to convert multiple avi and divx files to .3gp files. Any suggestions? Thanks.
Where can I find 3gp mobile converter?
First one is Aura Samsung Galaxy S III DVD video converter. It can ripp DVDs, convert video files and can download online videos.The other way is through Mac AVI to Samsung Galaxy S3 Converter. With it, you can easily convert videos and audio files like AVI, etc to Samsung Galaxy S3 playback MP4, 3GP, Divx, Xvid
Laz Zebbena
Good day! There are a lot of video converters for mobile phones nowadays. But finding the best one is hard due to the number of available software. I would suggest Xilisoft Video Converter. It lets you convert any type of video format to another and vice versa. Output quality is up to user's choice. It is a paid software but if you tend to use this type of software for a long period of time, you may want to consider purchasing it. But there are also free video converters. Just search them in Google. Cheers!
If you need to convert media files like AVI and DivX to another format like 3GP, try Format Factory. Download Format Factory on MajorGeeks.com. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. This software is a multi-functional media converter that is able to convert both audio and video files.
Supported audio formats include MP3, WMA, AMR, OGG, AAC, and WAV. Supported video formats include MP4, 3GP, MPG, AVI, WMV, FLV, and SWF. It also allows you to rip video DVDs and audio CDs. Note: read before clicking when installing Format Factory to avoid installing unwanted software. This program is bundled with several other unknown applications and tools and can display ads within the application as you use it.
You can also use ImTOO MPEG Encoder to convert your video files to another format. It supports Windows XP Service Pack 2, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 1 GHz Intel or equivalent AMD or faster processor, 256 MB RAM, 50 MB free space, and 16-bit video card.
