Where can I find Advent 3000 webcam drivers?
I just bought a used Advent Roma 3000 laptop that has Intel Celeron 2.2 GHz,  500 GB HDD and Windows 7 32 bit.  The webcam is not working and I'm thinking that it was not installed properly.  Where can I find Advent 3000 webcam drivers?
Answered By 0 points N/A #174613
Hello, Mellisa! It’s a good news for you that Advent 3000 webcam driver is available now. Though it’s not easy to get any other software, you can get it from brothersoft.com’s official http://www.brothersoft.com/downloads/advent-webcam-software.html website. Actually, if your previous version is not working as well, you need to uninstall it perfectly by “Advanced System Care””. Then you have to reinstall it. Hopefully you will get it. If any problem afterwards, please don’t feel shy to call me. Thanks!
