casey cock
30 points
Posted on - 03/08/2013
I recently formatted my desktop and I can't find my Aladdin Stuffit Dropstuff with Expander Enhancer trial software. I prefer to use Aladdin than WinZip as it has better compression and multimedia optimization. It can also expand and enhance .Tar formats. Where can I find the freeware software? I'm now on a Windows 8 platform. Thanks.
Where can I find Aladdin stuffit dropstuff with expander enhancer?
Hi Casey Cock,
Visit their site at http://my.smithmicro.com/stuffit-deluxe-mac.html
And find the software that you are looking for, you can download the free one but it is only a trial version,
And when the trial ends up, you are advised to purchase the full version in order for you to use its full features.
Hope this will help you. Thanks.
Stuffit is a tool for basic compression and expansion features , with its great features one can manage workflow efficiently.Goodness is the stufffit expander for windows now includes a context menu as you can expand files with a simple right click command right in windows explorer as well as support for expansion for SIT5, RAR and ZIPX archives.You can go online then visit this site stuffit.com and then download a free software but when the trial period is over you can get the full version of the software.
