Green Scott
50 points
Posted on - 12/20/2012
I need some divx player for my android phone. I do not need the updated version. I am looking for some old version specially 2011 released. Can any one please help me to find out android divx player 2011? I want a registered version.Â
Where can I find an android divx player 2011?
Hello there,
Divx Player is available for android online. You can get the registered version on Google Play. Let me share you a link where you can find one easily-
http://www.divx.com/en/software/divx
There are other players which plays divx files in case if this doesn't work in Android. The other players are Android Web Player, avi player etc.
Hope it helps!
Hi there user:
It’s kind of looking for a vintage car which is not so old in terms of model. Yes user, I can help you find that kind! Here’s the link where you can download the Old Version of DivX Player Plus 8.1.2 for your android, which was released on 21st of April 2011 (as requested). http://www.oldapps.com/divx_player.php?old_divx=37
Thanks for posting here at techyv.com
Best regards,
