Hi there. I have a Blackberry Curve. I was wondering where I can find the app Blackberry zombie pics? I would like to transform JPEG images into zombies with opacity of the effect layers. Can someone point me in the right direction? Thanks in advance.
Where can I find app blackberry zombie pics?
Hi Simon,
The app Zombie Booth is currently unavailable on Blackberry. I guess you will have to wait a while till it is launched for Blackberry!
You can however use the following website to convert your JPEG images into zombies:
http://www.zombieme.com/
You can use the app Zombie My Face Pro. It’s a free application which enables you to select a picture and modify it in order to make the person pictured look like a zombie.
This application comes with several effects and it has options that enables you to add masks and change colours at will.
You can also change the opacity.
Zombie My Face Pro can be downloaded here.
