Where can I find best hdd repair software?
I am facing problem with my hard disk drive in my laptop. I want to break by hard disks partition and set up a new partition. I need the best HDD repair software to setup a partition.
Can you please tell me Where can I find best HDD repair software?
Answered By 0 points N/A #178843
There are three solutions:
1) You can use a windows bootable cd to delete and create a new partition.
2) You can use Ultimate Boot CD. It’s a freeware and easy to use. Insert CD and restart computer, then follow instruction.
3) The last solution but the best in my opinion:
Download TestDisk and install it.
– In Dos menu , run testdisk.exe
– On Windows, run TestDisk (eg testdisk-6.13/testdisk_win.exe) from an account in the Administrators group. Under Vista, use right click run as administrator to run TestDisk.
– To work on a disk image, use:
image.dd testdisk to analyze a raw image of a disk (raw image)
testdisk image.E01 to work with an Encase EWF image
testdisk 'image.E *' if the image is spitted into several files
