Hello. I'm looking for a media player that can play most media files including OGG and divx files without installing codecs. Some media players don't play most of my OGG files. Where can I find the complete Tiger Player free download?
Hello there Horace,
Please do install latest versions of each media player so that you can be sure that the files or movies you want would play without any problem. As for tiger player, you may download it directly to their site or you may download it on other downloading sites. This link would redirect you to the home site of tiger player: http://www.mpcstar.com/ or you may go also to this site: http://tiger.softpile.com/tiger+player+5.1+free+download/
Hope it helps you.
Regards, Roland
I would recommend you the VLC media Player which is the best Player to play all kinds of formats. You can play Divx and many other files you want to play. You can also set the resolution according to your screen size. This media player can also be handled from the keyboard and you can enjoy the sound quality. The GOM player is also reliable to play the audio and video files. Download the these most recommended player from the following link.
VlC Media Player
