I want to edit some of my pictures.
Pictures are in RAW format like CR2 and CR format and taken by a Fuji camera. I have a Windows 7 Operating System.
So, I need a Fuji Windows7 raw Thumbnails software. Please help me to find a complete version.
How much may it costs?
Where can I find a complete version of fuji win7 raw thumbnails?
First install FastPictureViewer then install their codec pack. You can find it here: http://www.fastpictureviewer.com/codecs/
It supports common file formats like jpeg, jpg, png etc., but it also supports large amount of raw files including Fuji raw file types. With this application you can make Thumbnailer for your raw pictures and view them.
Regards.
Hello John Anderson,
There are two ways to preview or use software your raw picture file. If you use Photoshop CS2 or higher, you have to install one plug-in to open your file, the Adobe Camera Raw Plug-in. There is also freeware called Rawshooter essentials2006 that works on Windows OS.
Best of luck,
