Where can I find cooling fan replacements for older laptop models?
Ever since apple and other known brands have been releasing newer computer models, there have been many cases where cooling fan replacements of the older models are no longer carried by the stores.
Where can I find  fan replacement for older laptop models?
Are there any alternative fans for these models?
Best Answer by Arthur W Adams
Answered By 0 points N/A #152947
It depends on what model or how old your laptop is, if it is already old you cannot buy fan for it, the best thing about this situation is to replace your old laptop with a new one.
But if the model of your laptop is not that old, you can try here, http://www.nextag.com/ you can try also to Google your laptop model then include the word “fan for sale”.
Google will help you to find some available fan for sale for you.
You can try also to go where you bought it, contact them and they can help you a lot regarding with the parts of your laptop.
Answered By 20 points N/A #152948
Hi Ryan,
I agree with Ryan that it only depends on how old your laptop is. My recommendation for you is to buy new laptop there are many laptops available in the market that are affordable and has high quality.
A new laptop will make  your work fast and efficient. I recommend you the following brands of laptop:
1. Apple
2. Acer
3. Samsung
4. Lenovo
5. LG
Just choose any of those to solve your problem.
I hope I have help you.
